Programming Interfaces Guide
Socket Options
You can set and get several options on sockets through setsockopt(3SOCKET) and getsockopt(3SOCKET). For example, you can change the send or receive buffer space. The general forms of the calls are in the following list:
setsockopt(s, level, optname, optval, optlen);
and
getsockopt(s, level, optname, optval, optlen);
The operating system can adjust the values appropriately at any time.
The arguments of setsockopt(3SOCKET) and getsockopt(3SOCKET) calls are in the following list:
s
Socket on which the option is to be applied
level
Specifies the protocol level, such as socket level, indicated by the symbolic constant SOL_SOCKET in sys/socket.h
optname
Symbolic constant defined in sys/socket.h that specifies the option
optval
Points to the value of the option
optlen
Points to the length of the value of the option
For getsockopt(3SOCKET), optlen is a value-result argument. This argument is initially set to the size of the storage area pointed to by optval. On return, the argument's value is set to the length of storage used.
When a program needs to determine an existing socket's type, the program should invoke inetd(1M) by using the SO_TYPE socket option and the getsockopt(3SOCKET) call:
#include <sys/types.h>
#include <sys/socket.h>
int type, size;
size = sizeof (int);
if (getsockopt(s, SOL_SOCKET, SO_TYPE, (char *) &type, &size) <0) {
After getsockopt(3SOCKET), type is set to the value of the socket type, as defined in sys/socket.h. For a datagram socket, type would be SOCK_DGRAM.
