Programming Interfaces Guide
Interpreting apptrace Output
The following examples contain sample apptrace output from tracing a simple one-binary application, ls.
Example 10–1 Default Tracing Behavior
% apptrace ls /etc/passwd
ls       -> libc.so.1:atexit(func = 0xff3cb8f0) = 0x0
ls       -> libc.so.1:atexit(func = 0x129a4) = 0x0
ls       -> libc.so.1:getuid() = 0x32c3
ls       -> libc.so.1:time(tloc = 0x23918) = 0x3b2fe4ef
ls       -> libc.so.1:isatty(fildes = 0x1) = 0x1
ls       -> libc.so.1:ioctl(0x1, 0x540d, 0xffbff7ac)
ls       -> libc.so.1:ioctl(0x1, 0x5468, 0x23908)
ls       -> libc.so.1:setlocale(category = 0x6, locale = "") = "C"
ls       -> libc.so.1:calloc(nelem = 0x1, elsize = 0x40) = 0x23cd0
ls       -> libc.so.1:lstat64(path = "/etc/passwd", buf = 0xffbff6b0) = 0x0
ls       -> libc.so.1:acl(pathp = "/etc/passwd", cmd = 0x3, nentries = 0x0,
             aclbufp = 0x0) = 0x4
ls       -> libc.so.1:qsort(base = 0x23cd0, nel = 0x1, width = 0x40,
             compar = 0x12038)
ls       -> libc.so.1:sprintf(buf = 0x233d0, format = 0x12af8, ...) = 0
ls       -> libc.so.1:strlen(s = "") = 0x0
ls       -> libc.so.1:strlen(s = "/etc/passwd") = 0xb
ls       -> libc.so.1:printf(format = 0x12ab8, ...) = 11
ls       -> libc.so.1:printf(/etc/passwd
format = 0x12abc, ...) = 1
ls       -> libc.so.1:exit(status = 0)
The previous example shows the default tracing behavior, tracing every library call on the command ls /etc/passwd. The apptrace utility prints a line of output for every system call, indicating:
The output from ls is mixed in with the apptrace output.
Example 10–2 Selective Tracing
% apptrace -t \*printf ls /etc/passwd
The previous example shows how apptrace can selectively trace calls with regular-expression syntax. In the example, calls to interfaces ending in printf, which include sprintf, are traced in the same ls command as before. Consequently, apptrace only traces the printf and sprintf calls.
Example 10–3 Verbose Tracing
% apptrace -v sprintf ls /etc/passwd
  buf =    (char *) 0x233d0 ""
  format = (char *) 0x12af8 "%s%s%s"
/etc/passwd
The previous example shows the verbose tracing mode, where the arguments to sprintf are printed on multiple output lines for readability. At the end, apptrace displays the output of the ls command.
