Since all visible symbols in a library belong to some named set, the naming scheme can be used to label the symbols' ABI status. This labeling is done by associating all private interfaces with a set name beginning with SUNWprivate. Public interfaces begin with other names, specifically:
SYSVABI, for interfaces defined by the System V ABI definition
SISCD, for interfaces defined by the SPARC International SPARC Compliance Definition
SUNW, for interfaces defined by Sun Microsystems
These public, named sets are numbered with a major.minor numbering scheme. The minor number is incremented as new symbols are added to the set. The major number is incremented in the rare instance when an existing symbol changes incompatibly. When an existing symbol changes incompatibly, the version number in the library's file name is also incremented.
The definition of the Solaris library ABI is therefore contained in the libraries, and consists of the set of symbols that are associated with symbol version names that do not begin with SUNWprivate. The pvs command lists the symbols in a library.
