Solaris Common Desktop Environment: User's Guide
Setting the “Ramp-Up” Speed for the Pointer
You can set how fast the pointer reaches its maximum speed (when MouseKeys is set). To do this, adjust the slider marked “Time to max speed” (see Figure E–4.) This way, you can be more deliberate in moving the pointer. You can set the mouse to take up to four seconds to reach full speed.
