Solaris Common Desktop Environment: User's Guide
Keystrokes for AccessX Features
Table E–1 shows the various AccessX features and their associated keystrokes. You must start OpenWindows with the -accessx option to use these keystrokes.
Table E–1 Features and Their Keystrokes
Feature
Keystroke
Turn StickyKeys on or off.
Press Shift five times.
Turn StickyKeys off.
Press any two modifiers (e.g., Shift and Alt) at once. Note: You must turn this ability on from the Settings menu.
Turn MouseKeys on or off.
Alt - Shift - Num Lock
Move the pointer (when MouseKeys is turned on).
1-4, 6-9 keys on the numeric keypad
Click
Double-click
Press
Release
5
0
SELECT (mb1)
ADJUST (mb2)
MENU (mb3)
Turn RepeatKeys on or off.
Hold down Shift for eight seconds (beeps at four seconds)
Turn SlowKeys on or off.
