Solaris Common Desktop Environment: User's Guide
Using the Java Media Player
The following tasks can be performed on multimedia files using JMF.
To Open a New Java Media Player
To Exit the Java Media Player
To Open a File
To Close a File
To Open a URL
To Play a File
  1. From the File menu, select Open file.
  2. Enter the path or folder name in the text field.
  3. From the Files window, double click the file that you want to open.
To Stop or Pause a File
To Rewind a File
To Forward a File
The file will begin playing from the point you placed the slider.
To Adjust the Volume
You can either adjust or mute the volume for a file. To adjust the volume of a file:
To select mute for a file:
To Set the Play Rate for a File
  1. Place the cursor over the triangle on the lower left of the screen.
  2. Right-click the mouse button.
  3. From the pull-down menu select one of the options.
    • 1/10 speed - 1/10th the original rate
    • Half speed - 1/2 the original rate
    • Normal speed - the original rate
    • Double speed - twice the original rate
    • Triple speed - three times the original rate
    • Quadruple speed - four times the original rate
To Alter the Screen Size
  1. Place the cursor over the screen.
  3. From the pull-down menu select a zoom option:
    • Half Size - Shrinks the screen to half its original size
    • Normal - Alters the screen to accommodate the picture
    • Double Size - Expands the screen to twice its original size
    • Quadruple Size - Adjusts the screen to 4 times its original size
To Display Information on a Video File
