There are three menu items available:
File — controls whether or not you want Mixer Mode enabled (the default is enabled). Mixer mode enables you to listen to two audio sessions at once. For example, while listening to a Sun Microsystems broadcast you will also be able to hear the tone alerting you that you have new mail. Refer to the following illustration for an example of the Mixer mode enabled.
File is also where you will find the Exit command when you are ready to quit Audio Control.
View — controls your audio input and output. Toggling the Applications Control shows/hides (toggles) all Master and all Application processes.
Help — provides you with assistance in all areas of Audio Control. Refer to the following illustration for an example showing the Help pull-down menu.
