Solaris Common Desktop Environment: User's Guide
To Start Audio With the Waveform Displayed
  1. Choose Startup from the Options menu.
    The Options dialog box is displayed, with Startup selected as the Category. If the Options dialog box is already displayed, choose Startup from the Category menu.
  2. Click Waveform View Enabled or Stereo View Enabled.
  3. Click OK.
    The Options dialog box closes. The next time you start Audio the monaural or stereo waveform will be displayed. The Stereo View Enabled button is inactive if the current audio file is in monaural format.
