Solaris Common Desktop Environment: User's Guide
Appendix C Compose Key Sequences
If you are using the standard ISO 8859-1 (Latin-1) code set you can produce all characters by pressing the Compose key followed by other keys. These compose key sequences are listed in Table C–1.
Note –
ISO Latin-1 does not support the character for the Euro currency symbol (see Euro Currency Symbol).
On a SPARC keyboard, pressing the Compose key should illuminate the light on the key. On an IA keyboard, the Compose key is Control-Shift-F1 (hold the Control and Shift keys down and press the F1 key).
Table C–1 Compose Key Sequences for ISO Latin-1 Code Set
Compose
Result
Description
space
space
Space
Inverted exclamation
c
Cents
l
Pounds sterling
o
x
Currency symbol
y
Yen
Broken bar
s
o
Section
Umlaut/diaeresis
c
o
Copyright
a
ª
Feminine ordinal
Left guillemet
Not sign
Soft hyphen
r
o
Registered
Macron
0
Degree
Plus-minus
2
²
Superscript 2
3
³
Superscript 3
Prime/acute accent
u
µ
Mu/micro
P
Pilcro/paragraph
Middle dot
Cedilla
1
¹
Superscript 1
_
o
º
Masculine ordinal
Right guillemet
1
4
¼
Quarter
1
2
½
Half
3
4
¾
Three quarters
Inverted question
A
À
A grave
A
Á
A acute
A
A circumflex
A
à
A tilde
A
Ä
A umlaut
A
Å
A angstrom
A
E
Æ
AE ligature
C
Ç
C cedilla
E
È
E grave
E
É
E acute
E
Ê
E circumflex
E
Ë
E umlaut
I
Ì
I grave
I
Í
I acute
I
Π
I circumflex
I
Ï
I umlaut
D
Р
Eth
N
Ñ
N tilde
O
Ò
O grave
O
Ó
O acute
O
Ô
O circumflex
O
Õ
O tilde
O
Ö
O umlaut
x
x
x
Multiply
O
Ø
O slash
U
Ù
U grave
U
Ú
U acute
U
Û
U circumflex
U
Ü
U umlaut
Y
Ý
Y acute
T
H
Þ
Thorn
s
s
ß
Eszett/digraph s
a
à
a grave
a
á
a acute
a
â
a circumflex
a
ã
a tilde
a
ä
a umlaut
a
å
a angstrom
a
e
æ
ae ligature
c
ç
c cedilla
e
è
e grave
e
é
e acute
e
ê
e circumflex
e
ë
e umlaut
i
ì
i grave
i
í
i acute
i
î
i circumflex
i
ï
i umlaut
d
ð
eth
n
ñ
n tilde
o
ò
o grave
o
ó
o acute
o
ô
o circumflex
o
õ
o tilde
o
ö
o umlaut
Divide
o
ø
o slash
u
ù
u grave
u
ú
u acute
u
û
u circumflex
u
ü
u umlaut
y
ý
y acute
t
h
þ
thorn
y
ÿ
y umlaut
Note –
Localized keyboards do not all generate the same key codes for ISO Latin-1 characters. However, system translation tables take care of producing the right character code. The SunOS system finds its tables in /usr/share/lib/keytables.
