Each control in the Front Panel has a pop-up menu. The menu is different for each control.
Press mouse button 3 over the control.
The control's pop-up menu is displayed.
The contents of the pop-up menu depend on the behavior of the control and its location.
If the control starts an application, the first entry in the menu is a command that starts the application. Choosing the menu item has the same effect as clicking the control.
In addition, the pop-up menu may contain the following items:
Delete Subpanel - Removes the subpanel and its contents
Move Left - Interchanges the selected icon (and its subpanel) with the icon and subpanel immediately to its left
Move Right - Interchanges the selected icon (and its subpanel) with the icon and subpanel immediately to its right
Add Icon - Adds a blank icon immediately to the right of the selected control
Delete Icon - Removes the selected icon and its subpanel
Help - Displays On Item help for the control
The switch area is the portion of the workspace switch not occupied by other controls or workspace buttons.
The switch area pop-up menu contains the following items:
Add Workspace - Adds a workspace and creates a workspace button in the workspace switch
Help - Displays help for the workspace switch
Use the workspace buttons to change workspaces. Each button has its own menu.
The workspace button pop-up menu includes the following items:
Add Workspace - Adds a workspace to your list of workspaces
Delete - Deletes the workspace
Rename - Changes the button into a text field for editing the name
The pop-up menus for subpanels include a command for making the control the current Main Panel control.
The pop-up menu for subpanel controls includes the following items:
Promote to Front Panel - Duplicates the control in the Main Panel, replacing the current Main Panel control
Move Up - Interchanges the selected icon with the icon immediately above it
Move Down - Interchanges the selected icon with the icon immediately below it
