The Suggestion Box control on the Mail subpanel enables you to send an email to a product improvement proposals mailbox at Sun Microsystems.
Your suggestions should do one of the following:
Propose the addition of applications, utilities and services to Solaris
Propose enhancements to existing services and applications
Report functionality and nomenclature you find difficult to understand, learn, or use
The suggestion box facility does not provide any guaranteed level of service to you. For issues or bugs that you need to be resolved, use the normal bug reporting process, which is conducted through the distributor network.
