This is an advanced task that requires you to create a Front Panel configuration file. Advanced customization is covered in Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide.
Initially, the workspace switch has the four positions shown below.
Use this procedure to replace one of these controls. (Blank is also a control.)
Install the application you want placed in the switch into the Applications subpanel.
For example, if you want to add a Display System Load control to the switch, drag it from the Desktop_Tools application group to the Applications subpanel.
Locate the Front Panel configuration file created automatically when you installed the control in the Applications subpanel. The definition is located in the directory $HOME/.dt/types/fp_dynamic.
For example, when Display System Load is added to the Applications subpanel, it creates the file Xload1.fp.
Move the file from the $HOME/.dt/types/fp_dynamic directory to the $HOME/.dt/types directory.
Open the file in the $HOME/.dt/types directory for editing.
Edit the lines that define the CONTAINER_TYPE and CONTAINER_NAME to the following:
CONTAINER_TYPE SWITCH CONTAINER_NAME Switch
Edit the line that defines the position (POSITION_HINTS). For example, to put the control in the Blank location, set:
POSITION_HINTS 3
Save the configuration file.
Create another file in the $HOME/.dt/types directory.
The file name must end with .fp. For example. you might create a new file $HOME/.dt/types/DeleteBlank.fp.
Open the file for editing.
Open the file /usr/dt/appconfig/types/language/dtwm.fp in another editor window.
This file is read-only. You will not have to write to it.
In /usr/dt/appconfig/types/language/dtwm.fp, find the definition for the switch control you are replacing.
For example, this is the definition for the Blank control:
CONTROL Blank
TYPE blank
POSITION_HINTS 3
ICON FpblnkS
HELP_TOPIC FPOnItemSwitch
HELP_VOLUME FPanel
Copy the definition for the control you are replacing from /usr/dt/appconfig/types/language/dtwm.fp to the new configuration file.
For example, you would copy the definition for the Blank control to the new file $HOME/.dt/types/DeleteBlank.fp.
Add the line DELETE True to the end of the definition, within the curly braces:
CONTROL Blank
… HELP_VOLUME FPanel
DELETE True
Save the file.
Choose Restart Workspace Manager from the Workspace menu.
