There are two options that you can change using the Window List – Options dialog box:
Show Column
Double–clicking on a window in the list
These two options allow the setting of which columns will appear in the Window List and what action will be taken when you double-click on a window item in the Window List.
Click the State, Application, or Workspace check boxes for that column to be displayed.
The lack of a checkmark means the column will not be displayed.
The Window Title column will always be visible.
Window List provides the ability to select the effect of double-clicking a window entry in the Window List.
