There are a number of tasks that you can perform using the Window List. They are:
To Go To a Window – Goes to the selected window and gives it focus. If it is in another workspace, you are moved to that workspace.
To Get a Window – Moves the selected window from whatever workspace it is in to the one you are currently in and gives it focus.
To Lower a Window in the Stack – Lowers the selected window to the bottom of the window stack.
To Minimize the Selected Window(s) – Minimizes the selected window(s).
To Close a Window – Closes the selected window(s). If the window to be closed is the only window associated with an application, a confirmation dialog box appears.
To Terminate an Application – A confirmation dialog box appears and all windows associated with that application are closed.
To Move the Selected Window(s) Into Another Workspace – Moves the selected window(s) to the specified workspace.
To Occupy the Selected Workspace – Opens the Workspace Chooser dialog box and places the selected window in the workspace chosen from the list.
To Unoccupy the Selected Workspace – Removes the selected window from the current workspace. If this is the only workspace the selected window resides in, this option is greyed out.
To Cascade all Non-minimized Windows in a Workspace – Cascades all windows in the current workspace.
To Tile all Non-minimized Windows in a Workspace – Tiles all windows in the current workspace. Tiling can be horizontal or vertical.
Depending on the setting of the Window List Options, you may be able to double-click on the Window List entry and move to the workspace that contains the selected window or have the window move to the current workspace. Refer to To Set the Action of a Double-click on a Window Entry.
Select a window from the Window List.
Choose Get Window from the Window menu.
Window appears in the current workspace.
Select a window(s) from the Window List.
Choose Close Window from the Window menu.
(Optional) If the window being closed is the only window that contains a given application, a confirmation dialog box will appear. Click OK, if you want to close the window and terminate the application.
Choose Terminate Application from the Window menu.
Choose Move to Workspace from the Window menu.
Choose a workspace or All Workspaces.
Choose Occupy a Workspace from the Window menu.
Choose the workspace you want the window to occupy from the Occupy Workspace dialog box.
This occurs only in the current workspace.
Choose Cascade All in Workspace from the Window menu.
