If Image Viewer is already running, drop a PostScript file icon on an open Image Viewer window.
If Image Viewer is not running:
Drag a PostScript file icon from File Manager and drop it on the Workspace.
Press or click mouse button 3 over the PostScript file icon on the workspace and choose Open from the Workspace Object menu.
Image Viewer is started up and the PostScript file is displayed in Image Viewer's View window.
To remove the icon from the Workspace when you are finished with it, click mouse button 3 on the icon and select Remove From Workspace from the popup menu.
