Solaris Common Desktop Environment: User's Guide
To Move the Front Panel
  1. Press Alt+Tab to move the keyboard focus to the Front Panel.
  2. Press Alt+Spacebar to display the Front Panel menu.
  3. Press M, the menu's mnemonic for Move.
  4. Press the arrow keys to relocate the Front Panel.
    Hold down Control while you press an arrow key to speed up the movement of the Front Panel.
  5. When you've moved the Front Panel to where you want it, press Return.
    To cancel the move operation, press Esc.
