Solaris Common Desktop Environment: User's Guide
To Move a Window or Window Icon
  1. Press Alt+Tab to move the highlight to the window or icon you want to move.
  2. Press Alt+Spacebar to display the Window menu.
  3. Press M, the menu's mnemonic for Move.
  4. Press the arrow keys to relocate the window or icon.
    Hold down Control while you press an arrow key to speed up the movement of the window or icon.
  5. When you've moved the window or icon where you want it, press Return.
    To cancel the move operation, press Esc.
