Solaris Common Desktop Environment: User's Guide
To Log In to and Out of a Command-Line Session
Note –
Certain types of configurations (for example, X terminals) do not provide a Command Line Login mode option.
To enter Command Line Login mode:
  1. Choose Command Line Login from the Options menu.
    The login screen disappears and is replaced by a console prompt.
  2. Supply your login and password as prompted.
To leave Command Line Login mode:
    Type exit at a command-line prompt.
