Solaris Common Desktop Environment: User's Guide
To Change the Default Mailbox Directory
  1. Choose Move Menu Setup from the Options menu.
    The Move Menu Setup Options dialog box is displayed.
  2. Type the directory name in the Default Mailbox Folder field.
  3. (Optional) Type the IMAP server name in the IMAP Filing Server field.
    You can also specify the default mailbox folder for your IMAP server by editing the Default IMAP Folder field; the default is HomeDirectory/Mail.
  4. Click OK or Apply.
