Solaris Common Desktop Environment: User's Guide
To Change the Parameters Displayed
  1. Open the View menu to display the list of available parameters.
    Each parameter has a checkbox to indicate whether it is currently selected for display.
  2. Select or deselect the relevant menu item to display or remove any of the parameters.
    You can display any combination of parameters.
