You can easily print files, find or cancel print jobs, and get information about printers and print jobs through the desktop.
Your system may have more than one printer that you can use for printing. One of the printers will be designated as the default printer. The default printer is the printer that your desktop automatically uses if you submit a document for printing and you don't specify a printer name. When you first open your desktop, the default printer is shown in the Front Panel.
To find out how to display a printer other than your default printer in the Front Panel, see To Change the Front Panel Printer.
To find out the name of your default printer, double-click the Default printer control in the Personal Printers subpanel in the Front Panel.
This starts the Printer Jobs application. The name under the printer icon is the name of your default printer.
To designate a different printer as the default printer:
Go to your home folder and open the file .dtprofile.
Add or edit a line that sets a value for the LPDEST environment variable:
LPDEST=printer_device; export LPDEST
If you are using csh the syntax is:
setenv LPDEST printer_device
This change will take effect the next time you log out and back in again.
For example, the following line would change the default printer to the printer whose device name is laser3d.
LPDEST=laser3d; export LPDEST
setenv LPDEST laser3d
The desktop can print different types of files, as listed in Table 11–1.
Table 11–1 Types of Data That Can Be Printed (Initial Configuration)|
Type of Data |
Data Type Requirement |
Description |
Text file |
File name ends with.txt |
Text files containing ordinary (ASCII) text data |
PostScript |
File name ends with .ps, or content is recognized as PostScript data |
PostScript files (requires a PostScript printer) |
PCL |
File name ends with.pcl,or content is recognized as PCL data |
Printer Control Language files (requires a PCL printer) |
Data |
Contains text data |
The default data type assigned to all files containing ASCII data that do not match other data types |
If applications are installed on your system that create other types of files, your system administrator can add printing capabilities for them.
Ensure that your destination printer is capable of printing PostScriptTM or PCL files before you try to print them.
There are many ways to submit a file to a printer:
Using the Front Panel
Using File Manager
Using Print Manager
Using applications
Drag a single file or multiple files from File Manager to the Printer control in the Front Panel or to a Printer icon in the Personal Printers subpanel.
The system then displays a Print dialog box for specifying print options. A Print dialog box appears for each file you drag to the Printer control.
pscolor will not show on your system. It is only included as an example of a printer that has been added to a system.
Optional. Use the text fields in the Print dialog box to set additional print options. (See Setting Print Options Using the Print Dialog Box.)
Click OK in the Print dialog box to send the job to the printer.
Choose Print from the Selected menu or the file's pop-up menu.
The system displays a Print dialog box for specifying various print options.
Drag a file from File Manager to a printer icon in Print Manager.
In Print Manager, you can submit a document by dropping it on a printer icon or into the jobs list area to the right of a printer.
If you submit a job to a printer that is down (flag is showing), it may never be printed even though it appears in the jobs list.
The desktop displays the Print dialog box when you print text, PCL, PostScript, and data files (see Table 11–1).
When application data files, such as word processor documents, are submitted for printing, they may display their own unique Print dialog boxes.
Use the Print dialog box to set these print options:
Table 11–2 Setting Print Options|
Printer |
The destination for the print job. The text field initially displays the printer on which you dropped the data file. In this example, the document was dropped on a printer named lj4_n5. |
Copies |
The number of copies to print. The default is 1. |
Banner Page Title |
A title to appear on the banner page. The banner page is a sheet of paper that the printer prints before it prints the first page of your document. |
Print Page Numbers |
Prints page numbers on each page. If page numbering is selected, Print Manager will not display the true name of your document. Instead, the name in the jobs list will be STDIN:XXXXX, where XXXXX is a five-digit number. |
Print Command Options |
Other options that change the way printing is done. See the next section for more details on using this field. |
You can use the Print Command Options text field in the Print dialog box to set other print options. Type the proper lp command flag in the text field for the print option you want to use. To see a list of the lp command flags, type man lp in a Terminal window.
For example, one of the lp flags is -m. This flag tells the print server to send you a mail message that tells you when it is done printing your document. To use this flag you would type -m in the Print Command Options field of the Print dialog box. Then when your document is done printing, a message appears in your mailbox from the printer.
After you submit a document (print job) for printing, you can use the Print Manager or Printer Jobs applications to find out about the progress of the printing. Printer Jobs gives you information about jobs on a single printer. Print Manager shows all the printers that are on your system.
The Print Manager window is shown below. To find out how to modify it, see Changing the Print Manager Display.
The Printer Jobs application is the application you see when you open a single printer from the Front Panel. The Printer Jobs application is a simplified version of Print Manager that shows only a single printer instead of all the printers on your system. The functions that are available inside Printer Jobs work the same way as they do in Print Manager.
The pscolor printer is only shown in the figure as an example of a printer that has been added to a system. It will not be on your subpanel.
Information about the jobs waiting to be printed on a printer is displayed when you open a printer icon. A display area to the right of the printer icon displays an icon for each of the jobs waiting to be printed on it, and each job's position in line, job name, and owner.
There are three ways to open a printer:
Click the Open [+] button to the left of the printer icon.
Select a printer, then choose Open from the Selected menu or from the printer's pop-up menu (displayed by pressing Shift+F10 or mouse button 3).
Double-click the printer icon.
Your job will not appear in the Print Manager or Printer Jobs window if there are no jobs waiting to be printed when you send your job to the printer.
Close a printer if you don't want to see the jobs waiting to be printed on it.
Click the Close [-] button to the left of the printer icon.
Select a printer, then choose Close from the Selected menu or from the printer's pop-up menu (displayed by pressing Shift+F10 or mouse button 3).
Choose Find from the Printers menu.
Find is available in Print Manager but not in the Printer Jobs application.
Type the name of the print job you want to find in the Job Name field.
For example, typing cat will find all jobs that include the fragment “cat” in their name, such as “Catchall” and “catalog,” regardless of case.
To find jobs with the name “cat” only, you would select Exact match.
To find only jobs that match your capitalization, deselect Ignore case.
Find only finds print jobs that list you as the owner and it searches all printers, even those that are not currently displayed.
Click Start Find.
Once you have found a job, you can go directly to it in Print Manager or cancel it. To go to a found job, select the job and click Goto. To cancel a found job, select it and click Cancel Print Jobs.
Select a print job in the Print Manager or Printer Jobs window.
Choose Cancel from the Selected menu or from the print job's pop-up menu (displayed by pressing Shift+F10 or mouse button 3).
Click Yes in the confirmation dialog box.
The following properties can be displayed for print jobs:
Job name
Job owner
Job number
Job size
Time job submitted
Date job submitted
The term “not available” may appear in some fields to indicate that the print system is not supplying that information.
Choose Properties from the Selected menu or the print job's pop-up menu (displayed by pressing Shift+F10 or mouse button 3).
The properties are displayed.
The printer shown in the Front Panel is usually your default printer. You can change it to another printer, or add a printer to the Personal Printers subpanel.
This does not change your default printer assignment. To find out how to change the default printer, see To Change the Default Printer.
Open the Personal Printers subpanel (by clicking the arrow above the Printer control in the Front Panel) and verify that the icon for the printer you want to move to the Front Panel appears.
If the printer is not in the Personal Printers subpanel, add it by following the steps in To Add a Printer to the Personal Printers Subpanel.
In the subpanel, point to the printer icon you want to add to the Front Panel and select Put In Main Panel from the icon's pop-up menu (displayed by pressing Shift+F10 or mouse button 3).
To verify that the printer has been changed, click the Printer control in the Front Panel and check the name of the icon in the Printer Jobs window that appears.
Open the Personal Printers subpanel (by clicking the arrow above the Printer control in the Front Panel).
Start Print Manager.
Drag a printer icon from the Print Manager window to the Install Icon control in the open subpanel.
This section describes how to change display parameters in Print Manager.
Select how you want the print jobs represented:
Large Icon – Displays printers and print jobs as large icons
Small Icon – Displays printers and print jobs as small icons
Name Only – Displays printer and print jobs as only text
Details – Displays job owner, size, job number, and the date and time each job was submitted
Show Labels – Displays a description of each details row to the left of the job list area
The term “not available” may appear in some fields to indicate that the print server is not supplying that information
Click OK.
Choose Set Options from the View menu.
Adjust the interval gauge to specify how frequently printers are queried for information about their print jobs. The default is every 30 seconds.
Click OK.
Select which jobs you want shown:
Only Mine – Displays just your print jobs
Everyone's – Displays all print jobs
Click OK.
Select Message Line to display a message line at the bottom of the Print Manager window.
The message line shows the number of printers on your system and the number that are currently hidden. It also presents messages telling you when printer updates are being done.
Click OK.
Select Problem Flag to have a flag icon displayed next to printers when a problem is found with one of them.
For more information on the problem, you can double-click the Flag icon.
Click OK.
Choose Modify the Show List from the View menu.
Printers that are visible in the Print Manager window have highlighted names.
Click a non-highlighted printer to make it visible in the Print Manager window.
Click a highlighted printer to remove it from the main window. You can also use Select All to show all the printers or Deselect All to hide all the printers.
Click OK.
The following properties can be displayed:
Icon label
Icons
Description
Printer queue
Printer queue status
Device name
Device status
Select a printer in the Print Manager window or the printer in the Printer Jobs window.
Choose Properties from the Selected menu or from the printer's pop-up menu (displayed by pressing Shift+F10 or mouse button 3).
Click Find Set.
Select the new icon you wish to use.
If the icon you want is not visible, choose another folder from the Icon Folders menu. This dialog box will only display icons that have a complete set of all three sizes.
After you have selected an icon, click OK.
Click OK in the Properties dialog box.
