Solaris Common Desktop Environment: User's Guide
Printers and the Front Panel
The printer shown in the Front Panel is usually your default printer. You can change it to another printer, or add a printer to the Personal Printers subpanel.
To Change the Front Panel Printer
Note –
This does not change your default printer assignment. To find out how to change the default printer, see To Change the Default Printer.
  1. Open the Personal Printers subpanel (by clicking the arrow above the Printer control in the Front Panel) and verify that the icon for the printer you want to move to the Front Panel appears.
    If the printer is not in the Personal Printers subpanel, add it by following the steps in To Add a Printer to the Personal Printers Subpanel.
  2. In the subpanel, point to the printer icon you want to add to the Front Panel and select Put In Main Panel from the icon's pop-up menu (displayed by pressing Shift+F10 or mouse button 3).
    To verify that the printer has been changed, click the Printer control in the Front Panel and check the name of the icon in the Printer Jobs window that appears.
  1. Open the Personal Printers subpanel (by clicking the arrow above the Printer control in the Front Panel).
  2. Start Print Manager.
  3. Drag a printer icon from the Print Manager window to the Install Icon control in the open subpanel.
