Solaris Common Desktop Environment: User's Guide
To Change Screen Lock Settings
If the screen saver and screen lock are both enabled (On) and the Start Lock value is smaller than the Start Saver value, when the screen lock times-out it replaces the contents of the screen with the currently selected screen savers. If Start Lock is greater than Start Screen, then the automatic screen lock simply continues the current screen saver.
If the screen saver is disabled (Off) and automatic screen lock is enabled (On), when the screen lock times-out the contents of the screen are not covered with a screen saver.
  1. Click the Style Manager Screen control.
  2. Select the settings you want:
    • Screen Lock: Enables (On) or disables (Off) Screen Lock on a timeout. When this setting is changed, the new setting goes into effect immediately, even before the dialog box is closed.
    • Start Lock: Specifies the number of minutes from the last pointer move or keystroke before the screen lock starts. When this value is changed, the new value goes into effect immediately, even before you click OK.
  3. To save the changes, click OK. To return to the default settings, click Default.
