You can change the following aspects of your screen appearance:
Color Palettes
Workspace backdrops
Font sizes and font groups
You set your workspace colors through a color palette. The number of colors in the palette is determined by your display type and the Number of Colors selection.
Running certain applications may result in a phenomenon know as color flashing or colormap flashing, where the application appears with incorrect colors while the rest of the desktop appears normal, and when given the focus it displays with correct colors but the rest of the desktop does not. Color flashing is typically found in either of the following circumstances.
Your workstation does not use a 24 bit graphics card
You are running applications that are designed to use their own colormaps (thus placing a burden on the frame buffer)
This is due to fundamental limitations in XWindows when dealing with applications that do not use the default colormap. While you can't use more colors than your display allows, you can reduce the number of colors used by the desktop by choosing a lower-valued color usage in the Number of Colors to Use dialog box, or by exiting other graphics-intensive applications.
For example, if you have a high-color display and have selected More Colors for Desktop but you want to run a color-rich application such as a computer-aided design (CAD) program, you should choose More Colors for Applications or Most Colors for Applications to decrease the number of colors that the desktop uses. The remaining colors are available for the CAD program.
If you have closed all other graphics-intensive applications and your application is still experiencing color flashing, the following procedure may help eliminate the problem.
Open Style Manager.
Click Color.
The Color dialog box is displayed.
Click Number of Colors.
The Number of Colors To Use dialog box (see Figure 9–3) is displayed.
Select Most Colors For Applications and click OK.
Click Desktop background and choose a simple workspace background such as Gray Lt.
Make this session your home session by following the procedure inTo Set a Home Session.
Exit Style Manager and logout of CDE.
Login to CDE and re-open the application that previously experienced color flashing.
If the application no longer experiences color flashing, make a note of the current Style Manager settings; if it is still experiencing color flashing, the application has probably specified a list of colormaps to be installed, CDE is only installing the first colormap in this list, so you will need to cycle through the colormaps as explained in the following steps.
Use the following special keyboard keys to cycle through the colormaps.
Control-L2 (or Control-Again) |
Steps forward through the colormaps |
Control-L4 (or Control-Undo) |
Steps backward through the colormaps |
Cycling through the colormaps may end up installing the correct colormap, and will not affect the other windows on the desktop in any way. If you continue to experience colormap flashing, have your system administrator seek further information on SunSolveSM.
Your display type and the Number of Colors selection determine the number of color buttons that make up a palette. You will have two, four, or eight color buttons in the Color dialog box. The different color buttons in the palette control the colors used for different areas of the screen.
If you have eight color buttons, they will be used as follows (buttons numbered from left to right, top to bottom):
Active window borders
Inactive window borders
Switch for workspace 1 and every fourth additional workspace (workspace 5, 9, ...)
Text and list areas
Main window background and switch for workspace 2 and every fourth additional workspace (workspace 8, 12, ...)
Dialog box background and menu bar and switch for workspace 3 and every fourth additional workspace (workspace 7, 11, ...)
Switch for workspace 4 and every fourth additional workspace (workspace 6, 10, ...)
Front Panel background
If you have four color buttons, they will be used as follows (buttons numbered from left to right):
Main window and dialog box backgrounds and menu bar
Workspace switches and backgrounds
Text and list areas
If you have two color buttons, they will be used as follows (buttons numbered from left to right):
Everything else
Click the Style Manager Color control.
Select a palette from the Palettes list.
Click OK.
Workspace colors come from predefined color palettes. The Color dialog box lists the palettes that came with your system plus any palettes you have added.
Select a palette in the Color dialog box.
Double-click a color button to open the Modify Color dialog box, or click a color button and then click Modify.
Adjust the settings for the level of red, green, blue, brightness, or hue by adjusting the corresponding slider.
The old and new color samples will be displayed in the upper left corner of the Modify Color dialog box.
Repeat steps 2-4 to modify another color button.
Click Grab Color to display the grab pointer.
Move the pointer to an area of color on the screen that you want to grab.
Click to make that color the new color.
This causes the desktop to use one more color so applications have one fewer color available to them.
You can create your own palette by copying and modifying an existing palette.
Choose Add in the Color dialog box.
Type the new palette name and click OK in the Add Palette dialog box.
Modify the palette.
Click OK in the Color dialog box.
Adding a palette makes a copy of the currently selected palette with a unique name. You then create your custom palette by modifying the copy and the original palette is not changed.
Select the palette from the Palettes list.
Click Delete.
Click OK in the Delete Palette dialog box.
When you delete a palette, Style Manager prefixes the name of the palette with a ~ and stores a copy in the HomeDirectory/.dt/palettes directory.
Open a File Manager view showing HomeDirectory/.dt/palettes.
For system-supplied palettes, delete the file ~palette_name.dp.
For user-added palettes, rename the deleted palette from ~palette_name.dp to palette_name.dp.
Restart Style Manager (close, then reopen).
Click Number of Colors in the Color dialog box.
Select an option to set the number of colors used by the desktop.
Click OK.
You must log out and back in for the change to take effect.
The font size
and font group you select in Style Manager is used on titles, menu bars, window
labels and text. The new font size and font group is used as applications
are started. Existing windows will not reflect the change.
Click the Style Manager Font control.
Select a font size under Size.
Click OK to enable newly started applications to use the selected typeface, or click Cancel to cancel the operation.
Select a font group under Font Group.
Look at the Preview window labels and text, which show the new font typeface.
Choose Add in the Font dialog box.
Choose a font group from the System scrolling list and a font group from the User scrolling list.
Click OK to open the Font Group Name dialog box.
Enter a name in the New Font Group Name field of the Font Group Name dialog box for the new font group.
You can enter any non-blank name that you want.
Click OK to add a font group to the Font dialog box scrolling list.
Select a font group from the Font Group scrolling list on the Font dialog box.
Click the Delete button.
The Delete Font Group dialog box appears.
Click OK to delete the font group from the Font Group scrolling list.
Click the Attributes button.
The Font Attribute dialog box appears. It provides name and location information on the font size and font group you selected. This information varies according to the alias family (system, user, user bold) and character set you choose from the combo boxes at the top of the dialog box.
Click Close to dismiss the Font Attribute dialog box.
You
can select a backdrop pattern to cover each of your workspaces (the screen
area underneath your windows). A unique backdrop for each workspace adds variety
and helps you to quickly identify the workspace you are in.
