A new document named (UNTITLED) is created when you start Text Editor. To enter text in your document, see Entering Text. You provide a new file name when you save the document.
After finishing a document, you can create another document using the New command.
Choose New from the File menu.
The Text Editor window is cleared and a new document is created. If you have not saved your current document, a dialog box is displayed that enables you to save your document.
