Because dtterm only emulates a terminal, your control characters might not be what you are used to on a physical terminal. The ttyModes resource enables you to set control characters for your terminal emulator.
By default, Login Manager sets the control characters listed in Table 14–1.
Table 14–1 Terminal Control Characters
Control Name |
Character |
Definition |
erase |
Control+H |
Backspace erases characters |
intr |
Control+C |
Interrupt: Cancel the current operation and redisplay the command-line prompt. |
kill |
Control+U |
Stop an operation or application. |
start |
Control+Q |
Accept keyboard input: Used to continue an application that has been paused. |
stop |
Control+S |
Do not accept keyboard input: Used to pause an application. |
swtch |
Control+@ |
Switch between layers in a shell. |
For example, to interrupt an operation in progress, you press Control+C.
The syntax for the ttyModes resource is:
ttyModes: Control+C name
where name is the control, and C is the character. (^ is another way of expressing Control.) For example, the default value of ttyModes describing the preceding list is:
ttyModes: erase ^H intr ^C kill ^U start ^Q stop ^S swtch ^@
