Displaying the Menu Bar
By default, dtterm appears with a menu bar. You can remove it if you wish.
To Remove the Menu Bar
Choose Menu Bar from the Options menu.
The menu bar disappears from the dtterm window.
To Restore the Menu Bar
Click mouse button 3 anywhere within the dtterm window.
A pop-up menu appears containing items identical to those of the menu
bar.
The menu bar appears at the top of the dtterm window.
