About Solaris 9 Documentation lists books and other documentation you might need for installing and using the SolarisTM 9 operating environment.
About Solaris 9 Documentation includes the following chapters:
Chapter 1, Overview of Solaris 9 Documentation describes how the Solaris 9 documentation set is organized.
Chapter 2, Important Changes in the Solaris 9 Documentation Set summarizes the restructuring of the Solaris documentation set since the previous Solaris release.
Chapter 3, Finding the Documentation for Your Task lists Solaris 9 documents by tasks or subjects and provides a brief description of each document.
The docs.sun.comSM Web site enables you to access Sun technical documentation online. You can browse the docs.sun.com archive or search for a specific book title or subject. The URL is http://docs.sun.com.
The following table describes the typographic changes used in this book.
Table P–1 Typographic Conventions|
Typeface or Symbol |
Meaning |
Example |
AaBbCc123 | The names of commands, files, and directories; on-screen computer output |
Edit your .login file. Use ls -a to list all files. machine_name% you have mail. |
AaBbCc123 | What you type, contrasted with on-screen computer output |
machine_name% su Password: |
AaBbCc123 | Command-line placeholder: replace with a real name or value |
To delete a file, type rm filename. |
AaBbCc123 |
Book titles, new words, or terms, or words to be emphasized. |
Read Chapter 6 in User's Guide. These are called class options. You must be root to do this. |
The following table shows the default system prompt and superuser prompt for the C shell, Bourne shell, and Korn shell.
Table P–2 Shell Prompts|
Shell |
Prompt |
| C shell prompt | machine_name% |
| C shell superuser prompt | machine_name# |
| Bourne shell and Korn shell prompt | $ |
| Bourne shell and Korn shell superuser prompt | # |
