Solaris 9 Installation Guide
To Install Web Start Flash Archives on a Boot Environment (Command-Line Interface)
  1. Log in as superuser.
  2. Type:
    # luupgrade -f -n BE_name -s os_image_path -J 'profile'
    You must specify one of these options: -a, -j, or -J.
    -f
    Indicates to upgrade an operating system from a flash archive.
    -n BE_name
    Specifies the name of the boot environment that is to be upgraded.
    -s os_image_path
    Specifies the path name of a directory that contains an operating system image. This directory can be on an installation medium, such as a DVD-ROM, CD-ROM, or it can be an NFS or UFS directory.
    -J 'profile'
    Entry from a JumpStart profile that is configured for a flash installation. See pfinstall(1M) and Chapter 21, Custom JumpStart Installation (Topics) for information on the JumpStart software. You must specify one of -a, -j, or -J.
    -j profile_path
    Path to a JumpStart profile that is configured for a flash installation. See pfinstall(1M) and Chapter 21, Custom JumpStart Installation (Topics) for information on the JumpStart software. You must specify one of -a, -j, or -J.
    -a archive
    Path to the flash archive when the archive is available on the local file system. You must specify one of -a, -j, or -J.
    Example 33-3 Installing Web Start Flash Archives on a Boot Environment (Command-Line Interface)
    In this example, a flash archive is installed on the second_disk boot environment. The -J option is used to retrieve the archives. All files are overwritten on second_disk except shareable files.
    # luupgrade -f -n second_disk \
    -s /net/installmachine/export/solarisX/OS_image \
    -J 'archive_location http://example.com/myflash.flar'
