Log in as superuser.
To activate the boot environment, type:
# /usr/sbin/luactivate BE_name |
BE_name |
Specifies the name of the boot environment that is to be activated. |
Reboot.
# init 6 |
Use only the init or shutdown commands to reboot. Do not use the reboot, halt, or uadmin commands or the system does not switch boot environments. The last active boot environment is booted again.
In this example, the second_disk boot environment is activated at the next reboot.
# /usr/sbin/luactivate second_disk # init 6 |
