$PKG_INSTALL_ROOT is the location of the root (/) file system of the machine to which you are adding the package. This is set to the -R argument to the pkgadd command. For example, if the following command is invoked:
# pkgadd -R /a SUNWvxvm |
Then $PKG_INSTALL_ROOT is prepended to /a during the installation of the package.
$BASEDIR points to the relocatable base directory into which relocatable package objects are installed. Only relocatable objects are installed here. Non-relocatable objects (those that have absolute paths in the pkgmap file) are always installed relative to the alternate root (/), but not relative to the $BASEDIR in effect. If a package has no relocatable objects, then the package is said to be an absolute package (or non-relocatable), and $BASEDIR is undefined and not available to package procedure scripts.
For example, suppose a package's pkgmap file has two entries:
1 f none sbin/ls 0555 root sys 3541 12322 1002918510 1 f none /sbin/ls2 0555 root sys 3541 12322 2342423332 |
And the pkginfo file has a specification for $BASEDIR:
BASEDIR=/opt |
If this package is installed with the following command:
# pkgadd -R /a SUNWtest |
Then ls is installed in /a/opt/sbin/ls, but ls2 is installed as /a/sbin/ls2.
