Solaris 9 Installation Guide
To Test a Profile
  1. Locate a system on which to test the profile.
    If you are testing an upgrade profile, you must test the profile on the actual system that you intend to upgrade.
  2. Use the following decision table to determine what to do next.
    Test Scenario
    Instructions
    Test an initial installation profile and have a system that is running the Solaris 9 software
    Become superuser on the system and go to Step 5.
    Test an upgrade profile, or you do not have a system that is running Solaris 9 to test an initial installation profile
    Create a temporary Solaris 9 environment to test the profile. For details, see "To Create a Temporary Solaris 9 Environment to Test a Profile". Then, go to Step 3.
  3. Create a temporary mount point.
    # mkdir /tmp/mnt
  4. Mount the directory that contains the profile or profiles that you want to test.
    Mount Scenario
    Typing Instructions
    Mount a remote NFS file system for systems on the network
    mount -F nfs server_name:path /tmp/mnt
    Mount a UFS-formatted diskette
    mount -F ufs /dev/diskette /tmp/mnt
  5. To test the profile with a specific system memory size, set SYS_MEMSIZE to the specific memory size in Mbytes.
    # SYS_MEMSIZE=memory_size
    # export SYS_MEMSIZE
  6. Did you mount a directory in Step 4?
    • If yes, change the directory to /tmp/mnt.
      # cd /tmp/mnt
    • If no, change the directory to where the profile is located, which is usually the JumpStart directory.
      # cd jumpstart_dir_path
  7. Test the profile with the pfinstall(1M) command.
    # /usr/sbin/install.d/pfinstall -D:-d disk_config_file[[-c path]] profile
    Caution - Caution -
    You must include the -d or -D option. If you do not include one of these options, pfinstall uses the profile you specify to install the Solaris 9 software. All of the data on the system is overwritten.
    -D
    pfinstall uses the current system's disk configuration to test the profile. You must use the -D option to test an upgrade profile.
    -d disk_config_file
    pfinstall uses the disk configuration file, disk_config_file, to test the profile. If disk_config_file is not located in the directory where pfinstall is run, you must specify the path.
    For instructions on how to create a disk configuration file, see "Creating Disk Configuration Files".
    Note -
    You cannot use the -d disk_config_file option with an upgrade profile, install_type upgrade. You must always test an upgrade profile against a system's disk configuration, that is, you must use the -D option.
    -c path
    The path to the Solaris 9 software image. You use this option, for example, if the system is using Volume Manager to mount the Solaris 9 Software 1 of 2 CD for your platform.
    Note -
    The -c option is not required if you booted from a Solaris 9 DVD or a Solaris 9 Software 1 of 2 CD image for your platform. The DVD or CD image is mounted on /cdrom as part of the booting process.
    profile
    The name of the profile to test. If profile is not in the directory where pfinstall is being run, you must specify the path.
