If the archive is stored on an NFS server, use the following syntax for the archive_location keyword.
archive_location nfs server_name:/path/filename retry n |
server_name |
The name of the server where you stored the archive. |
path |
The location of the archive to be retrieved from the specified server. If the path contains $HOST, the Web Start Flash installation utilities replace $HOST with the name of the clone system that you are installing. |
filename |
The name of the Web Start Flash archive file. |
retry n |
An optional keyword. n is the maximum number of times the Web Start Flash utilities attempt to mount the archive. |
Examples:
archive_location nfs golden:/archives/usrarchive archive_location nfs://golden/archives/usrarchive
