Solaris 9 Installation Guide
cluster Profile Keyword (Adding or Deleting Clusters)
cluster cluster_name add_delete_switch
Note -
cluster (adding or deleting clusters) can be used with both the initial installation and upgrade options.
cluster designates whether a cluster is to be added or deleted from the software group that is to be installed on the system.
cluster_name must be in the form SUNWCname. To view detailed information about clusters and their names, start Admintool on an installed system and choose Software from the Browse menu.
add_delete_switch represents the option add or delete. Use add_delete_switch to indicate whether to add or delete the cluster that is specified. If you do not specify add_delete_switch, add is used by default.
When you use cluster (adding or deleting clusters) during an upgrade, the following condition apply:
