From the main menu, select Status.
A table similar to the following is displayed:
BE_name Complete Active ActiveOnReboot CopyStatus ------------------------------------------------------------------------ disk_a_S7 yes yes yes - disk_b_S7database yes no no COPYING disk_b_S8 no no no - |
In this example, you could not perform copy, rename, or upgrade operations on disk_b_S8 because it is not complete, nor on disk_b_S7database, because a live upgrade operation is in progress.
