attach(9E) should perform the common initialization tasks for each instance of a device. Typically, these tasks include:
Allocating per-instance state structures
Mapping the device's registers
Registering device interrupts
Initializing mutex and condition variables
Creating power manageable components
Creating minor nodes
Block device drivers create minor nodes of type S_IFBLK. This causes a block special file representing the node to eventually appear in the /devices hierarchy.
Logical device names for block devices appear in the /dev/dsk directory, and consist of a controller number, bus-address number, disk number, and slice number. These names are created by the devfsadm(1M) program if the node type is set to DDI_NT_BLOCK or DDI_NT_BLOCK_CHAN. DDI_NT_BLOCK_CHAN should be specified if the device communicates on a channel (a bus with an additional level of addressability), such as SCSI disks, and causes a bus-address field (tN) to appear in the logical name. DDI_NT_BLOCK should be used for most other devices.
For each minor device (which corresponds to each partition on the disk), the driver must also create an nblocks or Nblocks property. This is an integer property giving the number of blocks supported by the minor device expressed in units of DEV_BSIZE (512 bytes). The file system uses the nblocks and Nblocks properties to determine device limits; Nblocks is the 64–bit version of nblocks and should be used with storage devices with over 1 Tbyte of storage per disk.). See Device Properties for more information.
Example 11–1 shows a typical attach(9E) entry point with emphasis on creating the device's minor node and the Nblocks property. Note that because this example uses Nblocks and not nblocks, it calls ddi_prop_update_int64(9F) instead of ddi_prop_update_int(9F).
As a side note, this example shows the use of makedevice(9F) to create a device number for ddi_prop_update_int64(9F). makedevice(9F) itself makes use of ddi_driver_major(9F), which generates a major number from a pointer to a dev_info_t structure, just as getmajor(9F) does with a dev_t structure pointer.
static int xxattach(dev_info_t *dip, ddi_attach_cmd_t cmd) { int instance = ddi_get_instance(dip); switch (cmd) { case DDI_ATTACH: allocate a state structure and initialize it map the devices registers add the device driver's interrupt handler(s) initialize any mutexes and condition variables read label information if the device is a disk create power manageable components /* * Create the device minor node. Note that the node_type * argument is set to DDI_NT_BLOCK. */ if (ddi_create_minor_node(dip, "minor_name", S_IFBLK, instance, DDI_NT_BLOCK, 0) == DDI_FAILURE) { free resources allocated so far /* Remove any previously allocated minor nodes */ ddi_remove_minor_node(dip, NULL); return (DDI_FAILURE); } /* * Create driver properties like "Nblocks". If the device * is a disk, the Nblocks property is usually calculated from * information in the disk label. Use "Nblocks" instead of * "nblocks" to ensure the property works for large disks. */ xsp->Nblocks = size of device in 512 byte blocks; maj_number = ddi_driver_major(dip); if (ddi_prop_update_int64(makedevice(maj_number, instance), dip, "Nblocks", xsp->Nblocks) != DDI_PROP_SUCCESS) { cmn_err(CE_CONT, "%s: cannot create Nblocks property\n", ddi_get_name(dip)); free resources allocated so far return (DDI_FAILURE); } xsp->open = 0; xsp->nlayered = 0; ... return (DDI_SUCCESS); case DDI_RESUME: For information, see Chapter 9, Power Management default: return (DDI_FAILURE); } }
