The following buf structure members are important to block drivers:
int b_flags; /* Buffer Status */
struct buf *av_forw; /* Driver work list link */
struct buf *av_back; /* Driver work lists link */
size_t b_bcount; /* # of bytes to transfer */
union {
caddr_t b_addr; /* Buffer's virtual address */
} b_un;
daddr_t b_blkno; /* Block number on device */
diskaddr_t b_lblkno; /* Expanded block number on device */
size_t b_resid; /* # of bytes not transferred */
/* after error */
int b_error; /* Expanded error field */
void *b_private; /* “opaque” driver private area */
dev_t b_edev; /* expanded dev field */
b_flags contains status and transfer attributes of the buf structure. If B_READ is set, the buf structure indicates a transfer from the device to memory; otherwise, it indicates a transfer from memory to the device. If the driver encounters an error during data transfer, it should set the B_ERROR field in the b_flags member and provide a more specific error value in b_error. Drivers should use bioerror(9F) rather than setting B_ERROR.
Drivers should never clear b_flags.
Pointers that the driver can use to manage a list of buffers by the driver. See Asynchronous Data Transfers (Block Drivers) for a discussion of the av_forw and av_back pointers.
Specifies the number of bytes to be transferred by the device.
The kernel virtual address of the data buffer. Only valid after bp_mapin(9F) call.
The starting 32-bit logical block number on the device for the data transfer, expressed in DEV_BSIZE (512 bytes) units. The driver should use either b_blkno or b_lblkno, but not both.
The starting 64-bit logical block number on the device for the data transfer, expressed in DEV_BSIZE (512 bytes) units. The driver should use either b_blkno or b_lblkno, but not both.
Set by the driver to indicate the number of bytes that were not transferred because of an error. See Example 11–8 for an example of setting b_resid. The b_resid member is overloaded: it is also used by disksort(9F).
Set to an error number by the driver when a transfer error occurs. It is set in conjunction with the b_flags B_ERROR bit. See Intro(9E) for details regarding error values. Drivers should use bioerror(9F) rather than setting b_error directly.
For exclusive use by the driver to store driver-private data.
Contains the device number of the device involved in the transfer.
When a buf structure pointer is passed into the device driver's strategy(9E) routine, the data buffer referred to by b_un.b_addr is not necessarily mapped in the kernel's address space. This means that the driver cannot directly access the data. Most block-oriented devices have DMA capability, and therefore do not need to access the data buffer directly. Instead, they use the DMA mapping routines to allow the device's DMA engine to do the data transfer. For details about using DMA, see Chapter 8, Direct Memory Access (DMA).
If a driver needs to directly access the data buffer (as opposed to having the device access the data), it must first map the buffer into the kernel's address space using bp_mapin(9F). bp_mapout(9F) should be used when the driver no longer needs to access the data directly.
bp_mapout(9F) should only be called on buffers that have been allocated and are owned by the device driver. It must not be called on buffers passed to the driver through the strategy(9E) entry point (for example a file system). Because bp_mapin(9F) does not keep a reference count, bp_mapout(9F) will remove any kernel mapping that a layer above the device driver might rely on.
