Most character drivers use physio(9F) to do most of the setup work for DMA transfers in read(9E) and write(9E), as is shown in Example 10–5.
int physio(int (*strat)(struct buf *), struct buf *bp,
dev_t dev, int rw, void (*mincnt)(struct buf *),
struct uio *uio);
physio(9F) requires the driver to provide the address of a strategy(9E) routine. physio(9F) ensures that memory space is locked down (cannot be paged out) for the duration of the data transfer. This is necessary for DMA transfers because they cannot handle page faults. physio(9F) also provides an automated way of breaking a larger transfer into a series of smaller, more manageable ones. See minphys() Entry Point for more information.
static int
xxread(dev_t dev, struct uio *uiop, cred_t *credp)
struct xxstate *xsp;
int ret;
xsp = ddi_get_soft_state(statep, getminor(dev));
if (xsp == NULL)
return (ENXIO);
ret = physio(xxstrategy, NULL, dev, B_READ, xxminphys, uiop);
return (ret);
static int
xxwrite(dev_t dev, struct uio *uiop, cred_t *credp)
int ret;
if (xsp == NULL)
return (ENXIO);
ret = physio(xxstrategy, NULL, dev, B_WRITE, xxminphys, uiop);
return (ret);
In the call to physio(9F), xxstrategy() is a pointer to the driver strategy routine. Passing NULL as the buf(9S) structure pointer tells physio(9F) to allocate a buf(9S) structure. If the driver must provide physio(9F) with a buf(9S) structure, getrbuf(9F) should be used to allocate one. physio(9F) returns zero if the transfer completes successfully, or an error number on failure. After calling strategy(9E), physio(9F) calls biowait(9F) to block until the transfer is completed or fails. The return value of physio(9F) is determined by the error field in the buf(9S) structure set by bioerror(9F).
