ddi_copyin
copy data to a driver buffer
ddi_copyout
copy data from a driver
uiomove
copy kernel data using uio structure
ureadc
add character to a uio structure
uwritec
remove a character from a uio structure
ddi_getiminor
get kernel internal minor number from an external dev_t
ddi_model_convert_from
determine data model type mismatch
IOC_CONVERT_FROM
determine if there is a need to translate M_IOCTL contents
STRUCT_DECL
establish handle to application data in possibly differing data model
STRUCT_HANDLE
STRUCT_INIT
STRUCT_SET_HANDLE
SIZEOF_PTR
return size of pointer in specified data model
SIZEOF_STRUCT
return size of structure in specified data model
STRUCT_SIZE
return size of structure in application data model
STRUCT_BUF
return a pointer to the native mode instance of the structure
STRUCT_FADDR
return a pointer to the specified field of a structure
STRUCT_FGET
return specified field of a structure in application data model
STRUCT_FGETP
return specified pointer field of a structure in application data model
STRUCT_FSET
set specified field of a structure in application data model
STRUCT_FSETP
set specified pointer field of a structure in application data model
