Function Name |
Description |
check if device loses power with DDI_SUSPEND |
pci_report_pmcap |
report power management capability of a PCI device |
pm_busy_component |
mark component as busy |
pm_idle_component |
mark component as idle |
pm_raise_power |
raise the power level of a component |
pm_lower_power |
lower the power level of a component |
pm_power_has_changed |
notify power management framework of autonomous power level change |
pm_trans_check |
device power cycle advisory check |
Table B–28 Deprecated Power Management Functions
Function Name |
Description |
inform the system that a device's component is required |
pm_create_components | |
pm_destroy_components | |
pm_get_normal_power | |
pm_set_normal_power |
