When the system panics, it writes an image of kernel memory to the dump device. The dump device by default is the most suitable swap device. The dump is a system crash dump, similar to core dumps generated by applications. On rebooting after a panic, savecore(1M) checks the dump device for a crash dump. If one is found, it makes a copy of the kernel's symbol table (called unix.n) and dumps a core file (called vmcore.n) in the core image directory which by default is /var/crash/machine_name. There must be enough space in /var/crash to contain the core dump or it will be truncated. mdb(1) can then be used on the core dump and the saved kernel.
In the Solaris 9 operating system, crash dump is enabled by default. The dumpadm(1M) command is used to configure system crash dumps. Use the dumpadm(1M) command to verify that crash dumps are enabled and to determine the location of the directory where core files are saved. See the dumpadm(1M) man page for more information.
savecore(1M) can be prevented from filling the file system if there is a file called minfree in the directory in which the dump will be saved. This file contains a number of kilobytes to remain free after savecore(1M) has run. However, if not enough space is available, the core file is not saved.
