A quick way to set up the test machine is to unplug the keyboard before turning on the machine. The machine then automatically uses serial port A as the console.
Another way to set up the test machine is to use boot PROM commands to make serial port A the console. On the test machine, at the boot PROM ok prompt, direct console I/O to the serial line. To make the test machine always come up with serial port A as the console, set the environment variables input-device and output-device.
ok setenv input-device ttya ok setenv output-device ttya
The eeprom command can also be used to make serial port A the console. As superuser, execute the following commands to make the input-device and output-device parameters point to serial port A.
# eeprom input-device=ttya # eeprom output-device=ttya
Executing the eeprom commands causes the console to be redirected to serial port A at each subsequent system boot.
