A good strategy to avoid rendering a system inoperable is to make a copy of the kernel and associated binaries, and to boot that instead of the default kernel. To do so, make a copy of the drivers in /platform/* as follows:
# cp -r /platform/`uname -i`/kernel /platform/`uname -i`/kernel.test
When developing your driver, place it in /platform/`uname -i`/kernel.test/drv and boot that kernel instead of the default kernel:
# reboot -- kernel.test/unix
or from the PROM:
ok boot kernel.test/unix
This results in the test kernel and drivers being booted:
Rebooting with command: boot kernel.test/unix Boot device: /sbus@1f,0/espdma@e,8400000/esp@e,8800000/sd@0,0:a File and args: kernel.test/unix SunOS Release 5.9 Version Generic 32-bit Copyright 1983-2002 Sun Microsystems, Inc. All rights reserved. ...
Alternately, the module path can be changed by booting with the ask (-a) option:
ok boot -a
This results in a series of prompts which you can use to configure the way the kernel boots:
Rebooting with command: boot -a Boot device: /sbus@1f,0/espdma@e,8400000/esp@e,8800000/sd@0,0:a File and args: -a Enter filename [kernel/sparcv9/unix]: kernel.test/sparcv9/unix Enter default directory for modules [/platform/sun4u/kernel.test /kernel /usr/kernel]: <CR> Name of system file [etc/system]: <CR> SunOS Release 5.9 Version Generic 64-bit Copyright 1983-2002 Sun Microsystems, Inc. All rights reserved. root filesystem type [ufs]: <CR> Enter physical name of root device [/sbus@1f,0/espdma@e,8400000/esp@e,8800000/sd@0,0:a]: <CR>
