In kadb(1M), breakpoints can be set. When reached, the kernel will automatically drop back into kadb. The standard form of a breakpoint command is:
[module_name#] addr [, count]:b [command]
addr is the address at which the program will be stopped and the debugger will receive control, count is the number of times that the breakpoint address occurs before stopping, and command is almost any adb(1) command.
The optional module_name specifies deferred breakpoints that are set when the module is loaded. module_name identifies a particular module that contains addr. If the module has been loaded, kadb will try to set a regular breakpoint; if the module is not loaded, kadb will set a deferred breakpoint. When the module is loaded, kadb will try to resolve the location of the breakpoint and convert the breakpoint to a regular breakpoint.
Other breakpoint commands are:
:c |
Continue execution |
:d |
Delete breakpoint |
:s |
Single step |
:e |
Single step, but step over function calls |
:u |
Stop after return to caller of current function |
:z |
Delete all breakpoints |
The following example sets a breakpoint in scsi_transport(9F), a commonly used routine. Upon reaching the breakpoint, '$c' is used to print a stack trace. The top of the stack is displayed first. Note that kadb does not know how many arguments were passed to each function.
stopped at edd000d8: ta %icc,%g0 + 125 kadb[0]: scsi_transport:b kadb[0]: :c test console login: root breakpoint at: scsi_transport: save %sp, -0x60, %sp kadb[0]: $c scsi_transport(702bb578,1000,1,10000,0,702bb7fe) sdstrategy(1019c8c0,702bb61c,0,0,702bb578,70cad7b8) + 704 bdev_strategy(1042a808,70cad7b8,705f3efc,40,10597900,2000) + 98 ufs_getpage_miss(70cad7b8,0,10597900,0,0,4023ba8c) + 2b0 ufs_getpage(0,0,0,0,2000,4023ba8c) + 7c0 segvn_fault(4023ba8c,2000,ff3b0000,0,0,0) + 7c8 as_fault(1,ff3b0000,70d98030,2000,0,ff3b0000) + 49c pagefault(0,0,70df8048,705c7450,0,ff3b0000) + 4c trap(10080,10000,ff3c4ea4,70df8048,ff3b0000,1) + db4 kadb[0]: $b breakpoints count bkpt type len command 1 scsi_transport :b instr 4 kadb[0]: scsi_transport:d kadb[0]: :c
