devmap_devmem_setup(9F) is provided to export device memory to user applications.
devmap_devmem_setup(9F) has to be called from the driver's devmap(9E) entry point.
The syntax for devmap_devmem_setup() follows:
int devmap_devmem_setup(devmap_cookie_t handle, dev_info_t *dip,
struct devmap_callback_ctl *callbackops, uint_t rnumber,
offset_t roff, size_t len, uint_t maxprot, uint_t flags,
ddi_device_acc_attr_t *accattrp);
where:
Opaque device-mapping handle that the system uses to identify the mapping
Pointer to the device's dev_info structure
Pointer to a devmap_callback_ctl(9S) structure that allows the driver to be notified of user events on the mapping
Index number to the register address space set
Offset into the device memory
Length in bytes that is exported
Allows the driver to specify different protections for different regions within the exported device memory
Must be set to DEVMAP_DEFAULTS
Pointer to a ddi_device_acc_attr(9S) structure
roff and len describe a range within the device memory specified by the register set rnumber. The register specifications referred to by rnumber are described by the reg property. For devices with only one register set, pass zero for rnumber. The range described by roff and len are made accessible to the user's application mapping at the offset passed in by the devmap(9E) entry point. Usually the driver passes the devmap(9E) offset directly to devmap_devmem_setup(9F). The return address of mmap(2) then maps to the beginning address of the register set.
maxprot allows the driver to specify different protections for different regions within the exported device memory. For example, one region might not allow write access by setting only PROT_READ and PROT_USER.
Example 12–1 shows how to export device memory to an application. The driver first determines whether the requested mapping falls within the device memory region. The size of the device memory is determined using ddi_dev_regsize(9F). The length of the mapping is rounded up to a multiple of a page size using ptob(9F) and btopr(9F), and devmap_devmem_setup(9F) is called to export the device memory to the application.
static int
xxdevmap(dev_t dev, devmap_cookie_t handle, offset_t off, size_t len,
size_t *maplen, uint_t model)
struct xxstate *xsp;
int error, rnumber;
off_t regsize;
/* Set up data access attribute structure */
struct ddi_device_acc_attr xx_acc_attr = {
DDI_DEVICE_ATTR_V0,
DDI_NEVERSWAP_ACC,
DDI_STRICTORDER_ACC
xsp = ddi_get_soft_state(statep, getminor(dev));
if (xsp == NULL)
return (-1);
/* use register set 0 */
rnumber = 0;
/* get size of register set */
if (ddi_dev_regsize(xsp->dip, rnumber, ®size) != DDI_SUCCESS)
return (-1);
/* round up len to a multiple of a page size */
len = ptob(btopr(len));
if (off + len > regsize)
return (-1);
/* Set up the device mapping */
error = devmap_devmem_setup(handle, xsp->dip, NULL, rnumber,
off, len, PROT_ALL, DEVMAP_DEFAULTS, &xx_acc_attr);
/* acknowledge the entire range */
*maplen = len;
return (error);
