devmap_umem_setup(9F) is provided to export kernel memory to user applications. devmap_umem_setup() must be called from the driver's devmap(9E) entry point. The syntax for devmap_umem_setup() is as follows:
int devmap_umem_setup(devmap_cookie_t handle, dev_info_t *dip,
struct devmap_callback_ctl *callbackops, ddi_umem_cookie_t cookie,
offset_t koff, size_t len, uint_t maxprot, uint_t flags,
ddi_device_acc_attr_t *accattrp);
Opaque structure used to describe the mapping
Pointer to the device's dev_info structure
Pointer to a devmap_callback_ctl(9S) structure
Kernel memory cookie returned by ddi_umem_alloc(9F)
Offset into the kernel memory specified by cookie
Length in bytes that is exported
Specifies the maximum protection possible for the exported mapping
Must be set to DEVMAP_DEFAULTS
Pointer to a ddi_device_acc_attr(9S) structure
handle is a device-mapping handle that the system uses to identify the mapping. It is passed in by the devmap(9E) entry point. dip is a pointer to the device's dev_info structure. callbackops allows the driver to be notified of user events on the mapping. Most drivers set callbackops to NULL when kernel memory is exported.
koff and len specify a range within the kernel memory allocated by ddi_umem_alloc(9F). This range will be made accessible to the user's application mapping at the offset passed in by the devmap(9E) entry point. Usually the driver will pass the devmap(9E) offset directly to devmap_umem_setup(9F). The return address of mmap(2) will then map to the kernel address returned by ddi_umem_alloc(9F). koff and len must be page-aligned.
maxprot enables the driver to specify different protections for different regions within the exported kernel memory. For example, one region might not allow write access by only setting PROT_READ and PROT_USER.
Example 12–3 shows how to export kernel memory to an application. The driver first checks if the requested mapping falls within the allocated kernel memory region. If a 64-bit driver receives a mapping request from a 32-bit application, the request is redirected to the second page of the kernel memory area. This ensures that only applications compiled to the same data model will share the same page.
static int
xxdevmap(dev_t dev, devmap_cookie_t handle, offset_t off, size_t len,
size_t *maplen, uint_t model)
struct xxstate *xsp;
int error;
/* round up len to a multiple of a page size */
len = ptob(btopr(len));
/* check if the requested range is ok */
if (off + len > ptob(1))
return (ENXIO);
xsp = ddi_get_soft_state(statep, getminor(dev));
if (xsp == NULL)
return (ENXIO);
if (ddi_model_convert_from(model) == DDI_MODEL_ILP32)
/* request from 32-bit application. Skip first page */
off += ptob(1);
/* export the memory to the application */
error = devmap_umem_setup(handle, xsp->dip, NULL, xsp->ucookie,
off, len, PROT_ALL, DEVMAP_DEFAULTS, NULL);
*maplen = len;
return (error);
