Writing Device Drivers
DMA Model
The Solaris Device Driver Interface/Driver-Kernel Interface (DDI/DKI) provides a high-level, architecture-independent model for DMA. This allows the framework (the DMA routines) to hide such architecture-specific details as:
There are several abstractions that are used in the DDI/DKI to describe aspects of a DMA transaction. These include:
Rather than knowing that a platform needs to map an object (typically a memory buffer) into a special DMA area of the kernel address space, device drivers instead allocate DMA resources for the object. The DMA routines then perform any platform-specific operations needed to set the object up for DMA access. The driver receives a DMA handle to identify the DMA resources allocated for the object. This handle is opaque to the device driver; the driver must save the handle and pass it in subsequent calls to DMA routines, but should not interpret it in any way.
Operations are defined on a DMA handle that provide the following services:
