Writing Device Drivers
Performing Third-Party DMA Transfers
In general, the driver should perform these steps for third-party DMA.
  1. Allocate a DMA channel.
  2. Retrieve the system's DMA engine attributes with ddi_dmae_getattr(9F).
  3. Lock the DMA object in memory (see physio(9F) or ddi_umem_lock(9F)).
  4. Allocate DMA resources for the object.
  5. Program the system DMA engine to perform the transfer with ddi_dmae_prog(9F).
  6. Perform any required object synchronizations.
  7. Stop the DMA engine with ddi_dmae_stop(9F).
  8. Release the DMA resources.
  9. Deallocate the DMA channel.
Certain hardware platforms restrict DMA capabilities in a bus-specific way. Drivers should use ddi_slaveonly(9F) to determine if the device is in a slot in which DMA is possible.
