A DMA engine on an ISA bus in an IA machine has the following attributes:
It accesses only the first 16 megabytes of memory.
It cannot cross a 1 megabyte boundary in a single DMA transfer.
It has a 16-bit counter register.
It can handle byte-aligned transfers.
It supports 1-, 2- and 4-byte burst sizes.
It has a minimum effective transfer size of 1 byte.
It can hold up to 17 scatter-gather transfers.
The device operates on sectors only (for example a disk).
The resulting attribute structure is:
static ddi_dma_attr_t attributes = { DMA_ATTR_V0, /* Version number */ 0x00000000, /* low address */ 0x00FFFFFF, /* high address */ 0xFFFF, /* counter register max */ 1, /* byte alignment */ 0x7, /* burst sizes */ 0x1, /* minimum transfer size */ 0xFFFFFFFF, /* max xfer size */ 0x000FFFFF, /* address register max */ 17, /* scatter-gather */ 512, /* device operates on sectors */ 0, /* attr flag: set to 0 */ };
