Character device drivers normally perform I/O in a byte stream. Examples of devices using character drivers include tape drives and serial ports. Character device drivers can also provide additional interfaces not present in block drivers, such as I/O control (ioctl) commands, memory mapping, and device polling. See Chapter 10, Drivers for Character Devices for more information.
The main task of any device driver is to perform I/O, and many character device drivers do what is called byte-stream or character I/O. The driver transfers data to and from the device without using a specific device address. This is in contrast to block device drivers, where part of the file system request identifies a specific location on the device.
The read(9E) and write(9E) entry points handle byte-stream I/O for standard character drivers. See I/O Request Handling for more information.
For certain devices, such as frame buffers, application programs having direct access to device memory is more efficient than byte-stream I/O. Applications can map device memory into their address spaces using the mmap(2) system call. To support memory mapping, device drivers implement segmap(9E) and devmap(9E) entry points. For information on devmap(9E), see Chapter 12, Mapping Device and Kernel Memory. For information on segmap(9E), see Chapter 10, Drivers for Character Devices.
Drivers that define the devmap(9E) entry point usually do not define read(9E) and write(9E) entry points, as application programs perform I/O directly to the devices after calling mmap(2).
